Neil_S5 Posted May 2, 2016 Posted May 2, 2016 Evening guys and girls, I have just bought myself an 2012 S5 convertible and love it to bits already - here's the but... I have found it has the issue with water leaking into the boot on the left hand side but the fuses, the yellow sponge at the bottom is soaked :-( anyway will be calling up the dealership tomorrow to get them to sort it under warranty but the question I have is the boot lid and how it is meant to open. i was under the impression that when you pressed the boot unlock button twice on the key fob the boot lid is meant to pop up and open - is that right? As mine currently doesn't *sigh* thanks Neil
James Posted May 4, 2016 Posted May 4, 2016 Hi Neil, Have you also tried pressing and holding - not sure if it's any different for the cab rather than the coupe?
Neil_S5 Posted May 4, 2016 Author Posted May 4, 2016 Hi James, Yeah tried that - it just unlocks, not sure if its the boot struts have lost their gas as its not that easy to open either. really need to see if someones else that has a cab knows if it should or not.
James Posted May 6, 2016 Posted May 6, 2016 On 5/4/2016 at 0:44 PM, Neil_S5 said: Hi James, Yeah tried that - it just unlocks, not sure if its the boot struts have lost their gas as its not that easy to open either. really need to see if someones else that has a cab knows if it should or not. Hmm could be. I'm sure I've read somewhere that it's different on the cab so yes I suppose it would be good to try and find someone else with a cab to ask. Or, just a thought - why not see if your local Audi dealer has one you can try? 1
Abvrs Posted November 4, 2016 Posted November 4, 2016 I've just purchased a S5 convertible, currently in shop for oil consumption test, I noticed the loan a6 boot popped open as you describe, I asked why mine only unlocks, apparently convertible does not do this, not sure why not though.
Audi Owners Club. Posted November 7, 2016 Posted November 7, 2016 I think James is right that the convertible does not do this...more than likely a feature that doesn't enable the boot to open when there is any likelihood of the roof being in anything but a closed position.
S5333cab Posted January 18, 2017 Posted January 18, 2017 On Wednesday, May 04, 2016 at 0:44 PM, Neil_S5 said: Hi James, Yeah tried that - it just unlocks, not sure if its the boot struts have lost their gas as its not that easy to open either. really need to see if someones else that has a cab knows if it should or not. My cab just unlocks boot. As for the water you have 2 vents either side on car there is a fault with them. Just had mine done everything OK. 1
