cliffcoggin Posted May 9, 2016 Posted May 9, 2016 I use the cigarette lighter outlet for a satnav in my A3 Sportback and was surprised to find the outlet is live even when the ignition is off, leading to the possibility of draining the battery if I am not careful. Is this normal?
cliffcoggin Posted May 10, 2016 Author Posted May 10, 2016 Thanks James. I guess I shall have to poke around in the wiring to find a supply that is switched with the key.
James Posted May 11, 2016 Posted May 11, 2016 I always find using a fuse tap/piggyback is quite a neat way of doing it as you don't have to chop any wires etc
cliffcoggin Posted May 11, 2016 Author Posted May 11, 2016 I haven't seen those until now. I must investigate further.
James Posted May 13, 2016 Posted May 13, 2016 On 5/11/2016 at 9:45 AM, cliffcoggin said: I haven't seen those until now. I must investigate further. They're pretty useful. I usually use them for hardwiring dash cams etc
cliffcoggin Posted May 18, 2016 Author Posted May 18, 2016 After a couple of false starts the sat nav is now permanently wired to a key switched circuit. Thanks for the tip James about piggy back fuse taps. An added benefit to the job is having less than a foot of wire on show above the dash, so it looks far tidier.
James Posted May 24, 2016 Posted May 24, 2016 On 5/18/2016 at 2:47 PM, cliffcoggin said: After a couple of false starts the sat nav is now permanently wired to a key switched circuit. Thanks for the tip James about piggy back fuse taps. An added benefit to the job is having less than a foot of wire on show above the dash, so it looks far tidier. Glad you managed to sort it - the fuse taps are pretty useful for all sorts of things!
krolwioski Posted February 12, 2019 Posted February 12, 2019 Are you able to give more details how to do that? As i do have same issue. I have bought some amazon fuse taps, but it did not work for me. Maybe those needs to be special piggy back? EDIT: Looks like I have an answer already, as I have flipped fuse taps around, will test that later.
