jonny747 Posted May 16, 2016 Posted May 16, 2016 Hi All I have noticed a knocking type of noise from front passenger side and it gets louder when taking right hand corners, only just bought car and it's recently had new brakes and disks all round. It sounds like a sticky caliper on a warped disk but there is no vibration or wobble on steering wheel, als i have jacked up the car and checked the wheels are moving freely and all seems to be ok ?? Any clues please
James Posted May 17, 2016 Posted May 17, 2016 If it was a warped disc you would get vibration through the pedal when braking from motorway speeds. Knocking more likely to be a worn bush in my opinion.
jonny747 Posted May 17, 2016 Author Posted May 17, 2016 Cheers James I'll have it checked out, doesn't really sound like a bush though but long time since last owned an Audi so not 100% on sounds just yet
James Posted May 18, 2016 Posted May 18, 2016 Just when I think of a "knocking" noise I certainly wouldn't think of a warped brake disc, though it's hard to tell without actually hearing it lol
jonny747 Posted May 20, 2016 Author Posted May 20, 2016 It's not a mechanical knocking as such not like an engine knocking sound but more of something catching on wheel or drive shaft, obviously it becomes louder the faster I go and speeds up or slows down with the speed I go hence the thought of a sticky caliper also becomes more noticeable when turning right therefore all weight on left side ?
jonny747 Posted May 24, 2016 Author Posted May 24, 2016 I will try James but don't think its loud enough to pick up.... Its getting slightly louder by the day I would put it straight into garage but need car for work so catch twenty two... Trying to find a good reputable garage that opens on a Saturday is !Removed! neigh impossible !!! I'm Pretty sure its a calliper as tonight when pulling into my drive on full lock I heard a grinding noise like the brakes locking on or catching on something plus I'm now getting slight vibration in steering wheel on my commute to work.
James Posted May 25, 2016 Posted May 25, 2016 14 hours ago, jonny747 said: I will try James but don't think its loud enough to pick up.... Its getting slightly louder by the day I would put it straight into garage but need car for work so catch twenty two... Trying to find a good reputable garage that opens on a Saturday is !Removed! neigh impossible !!! I'm Pretty sure its a calliper as tonight when pulling into my drive on full lock I heard a grinding noise like the brakes locking on or catching on something plus I'm now getting slight vibration in steering wheel on my commute to work. Give it a try you never know!
jonny747 Posted May 25, 2016 Author Posted May 25, 2016 Sorry James I did try but all you can hear is road noise and traffic noise
Simon H Posted May 28, 2016 Posted May 28, 2016 Sounds like a suspension bush or the strut top mount.
Dominator27548 Posted May 29, 2016 Posted May 29, 2016 Hi, I had a similar noise a few days after buying my A4. Took it to a local garage and it was found that the rear clip on the back of the brake pad had sheared off and got stuck in the piston leaving the pad to be loose in the caliper. Pads only had a few hundred miles on them and we're DELPHI pads fitted by kwik-fit.
jonny747 Posted June 1, 2016 Author Posted June 1, 2016 Cheers guys I'm gonna try and book it in next week as doing my nut now !! Will get a service at same time just need to find a good garage near where i live.....
