Hi guys I'm just woundering what the standard boost pressure should be for my a3 2.0 tdi.
And im thinking about getting egr delete but can you just bolt it on or do you have to have it mapped off
An EGR by-pass is a good place to start...try one with the small hole in the middle, its usually enough to fool the system in believing everything is still in situ.
http://www.ebay.co.uk/itm/like/AUDI-A3-TT-2-0-DIESEL-EGR-VALVE-BLANKING-PLATE-1-5MM-THICK-STEEL-HD/331800987250?hlpht=true&ops=true&viphx=1&_trksid=p5197.c100068.m2280&_trkparms=ao%3D1%26asc%3D20140211130857%26meid%3D67afb27797b24f169296226b76d2d098%26pid%3D100068%26clkid%3D5935374487797316359&_qi=RTM2063723
Boost pressure for your model should be in the region of 1.1 - 1.3 bar
