curtisr0213 Posted July 12, 2016 Posted July 12, 2016 hi ive looked for alot of threads but none seem to have my exact problem unless im not understanding them properly, i have a a3 8p1 its 2004 1.9tdi now when i accelerate from standstill or floor it whilst moving between idle revs and 2500 rpm it ives a heavy judder vibrate then is fine even if i just pull away in first clutch only, it doesnt do this in reverse, occasionly very very rarely the clutch has started slipping a couple of hours into driving.... anyone got any ideas ? thanks
Audi Owners Club. Posted July 13, 2016 Posted July 13, 2016 HI Curtis...welcome to the Club! I would imagine it is a drivetrain issue (clutch, transmission, flywheel) which would be worth dropping into a garage to have checked before it gets any worse. Additionally, it could be an engine mount or stabiliser that needs replacing...either way, worth dropping into a garage to check out Let us know how you get on with it Regards Trevor - Admin
curtisr0213 Posted July 13, 2016 Author Posted July 13, 2016 hi, ive had a few people i know look at it yesterday morning and theyve pointed out my engine moves alot more than its supposed to, theyve also said it looks like a engine mount so ill get it looked at tomorrow but thanks for the reply it gives me a few things to go on
Audi Owners Club. Posted July 14, 2016 Posted July 14, 2016 Let us know how you get on Curtis, hopefully it is something cheap to replace
curtisr0213 Posted July 21, 2016 Author Posted July 21, 2016 hi, i had someone look at it took them about a minute it turns out its the lower engine mount a easy enough thing to replace and not to expensive (around the £30 mark) thanks for the help hopefullt this helps someone else in the future.. 1
