SvenErlandsen Posted July 13, 2016 Posted July 13, 2016 Have 2001 A2 and the interior fan is instable. Both in auto and manual, but mostly in auto. What can be wrong?
Audi Owners Club. Posted July 14, 2016 Posted July 14, 2016 Hi Sven...welcome to the Club! I have found that the fan motors tend to dry up on the bearings and become semi-seized...a bit of lube spray to ease the bearing and it's then fine. Otherwise if its a control issue...try cleaning out the ambient air temperature sensor aperture on the dashboard as these can block up with dust, etc. Regards Trevor - Admin 1
SvenErlandsen Posted July 15, 2016 Author Posted July 15, 2016 On 14/07/2016 at 1:37 PM, Trevor said: Hi Sven...welcome to the Club! I have found that the fan motors tend to dry up on the bearings and become semi-seized...a bit of lube spray to ease the bearing and it's then fine. Otherwise if its a control issue...try cleaning out the ambient air temperature sensor aperture on the dashboard as these can block up with dust, etc. Regards Trevor - Admin Thanks! I will give it a try
