I have just bought a 2008 Q7 Sline. When I press the Nav button, mmi says it's not installed. I went hunting in the boot and found the dvd drive is installed and there appears to be a dvd in the drive. I can't eject the disc as there appears to be no power to it or its just a dead drive.
Is there a fuse to check for the dvd drive or should I get another drive and see if it works? I unplugged the drive to take in the house and the mmi stopped working so I've plugged it back in.
Any help would be gratefully received.
Hi Ben
I have read before that the units tend to fail and also recall that there are plenty used ones available at a reasonable cost...maybe worth going that route
Let us know how you get on with this
Regards   Trevor - Admin
I've ordered another drive from eBay so will see how that goes? I've got another drive with the same model number as my 1. Will I need to code the replacement 1?
  • 6 months later...
Sorry for the delayed reply. Swapping the drive out for another unit worked fine. It was the same part number so needed no coding.
