daily Posted July 28, 2016 Posted July 28, 2016 can anyone help my q7 has a intermittent starting issue it runs fine but now and again it just turns the engine but wont fire after roughly 15 mins its starts and runs fine. audi cant find any faults please help me on this.
Audi Owners Club. Posted August 9, 2016 Posted August 9, 2016 Hi Kenneth...welcome to the Club! It sounds like a Crankshaft Sensor if the engines turning but not firing as the sensor feeds info to the ECU to control spark and fuel so if you're not getting those then it won't run. Worth checking for a scope waveform or live data from the sensor before condemning though. Let us know how you get on with it Cheers Trevor - Admin
wuciwug Posted October 3, 2016 Posted October 3, 2016 Bit late to the party. I had very similar problems, would crank for 10-14 seconds before starting, only happened randomly, progressively happened more and more until... New starter motor solved it. Now starts in <1 second, hot cold or otherwise 1
Salik Posted September 5, 2017 Posted September 5, 2017 On 7/28/2016 at 8:35 PM, daily said: can anyone help my q7 has a intermittent starting issue it runs fine but now and again it just turns the engine but wont fire after roughly 15 mins its starts and runs fine. audi cant find any faults please help me on this. Expand My Q7 is having the same issue. Runs fine. Sometimes refuses to start (this has happened only when engine is still hot). Engine cranks for about 2 seconds and stops (no firing at all). It's not the starter motor as cranking speed is very good. This has started to happen after replacing my battery (could be a coincidence). Also, I've noticed that the led in the door doesn't flash when you lock it through the fob (it remains solid red). The car, however starts if you leave it for 15 minutes. Could it be something related to immobiliser? Did you manage to solve the issue in your Q7?
Markuza Posted September 13, 2019 Posted September 13, 2019 Hi Salik, did you fix the intermittent problem?
Ashley allen Posted June 22, 2023 Posted June 22, 2023 Hi I have the same issue with my q7 fires for 2 secs then nothing but I could leave it 15 mins and starts fine runs fine their is no rhythm or rhyme to when it will do it sometimes starts after 15 mins but has taken up to a couple of hours ,it’s been in the garage for a week and they can’t find a fault any idea on the fault or has anyone solved their issue cheers ash
Ashley allen Posted July 17, 2023 Posted July 17, 2023 It’s been nearly 3 weeks since I changed my cam shaft sensor on my q7 and the intermittent fault is no longer an issue hope this helps someone in the future kind regards ash
