Bairdy Posted July 31, 2016 Posted July 31, 2016 Hi guys I'm new to the club and hoped somebody Could help me out with a problem I have with my 2012 Audi A4 S line 2.0 Tdi. I have just had a duel mass flywheel and clutch fitted on friday collected the car from a vw indy specialist and he said there was a problem this sign appears when i start the car Stabilization fault and the skid sign on my rev counter i also noticed that my see you home lighting disnt work last night and my drivers xenon bulb kept going out but lighting again when i turned it off an on again but go out again the car is booked back in garage Tuesday just wondered if there was anything i could do or anyone had the same problem when dis connecting the battery sorry about the long right up guys any help much appreciated thanks martin
Audi Owners Club. Posted August 2, 2016 Posted August 2, 2016 Hi Martin...welcome to the Forum! It sounds like something like an ABS wheel sensor that could be bringing the warning light on (believe it is the wheel bearing type of sensor and if the hub nut/bolt isn't tightened up correctly, this can affect the sensor). As for the lighting faults, not sure exactly but may have been disconnected in the process of repair and maybe not replaced correctly...but the headlamp sounds like a ballast fault. Let us know how you get on with it Regards Trevor
