Matta3sline Posted August 11, 2016 Posted August 11, 2016 Hi guys had my 2.0tdi sline pd140 couple of weeks went to get it remapped but it was overboosting standard. In vag com it has an overboost exceedes limit fault code. The car doesnt go into limp mode at all tho. Any idea how to fix this is the actuator movent wen i use the vac hose trick while running thanks guys
Audi Owners Club. Posted August 12, 2016 Posted August 12, 2016 Hi Matt...can only think it may be the variable vanes sticking...could try running a specialist cleaner through the induction system or directly in the turbo. http://www.ebay.co.uk/itm/Diesel-Engine-Turbo-Cleaner-Cures-Limp-Home-Mode-Variable-Vane-Turbos-/152003334878?hash=item23641ad2de:g:lQ4AAOSwZ8ZW2O4l
