The Devil's Reject Posted August 18, 2016 Posted August 18, 2016 Hi Iam a newbie on here I took my a3 3.2 out the other day just a standard drive out and after I parked up after a few hours I noticed a patch of coolant had dropped out on the passenger side of engine Any ideas on what it could be Thanks
Audi Owners Club. Posted August 25, 2016 Posted August 25, 2016 Hi Ryan...welcome to the Club! It may be the drain for the Air Conditioning where the moisture drawn out from inside is released under the car. If you dip your finger into it and it doesn't smell of chemicals (antifreeze) then chances are its just water...either that or the local cat has relieved itself under your car, so don't suggest tasting the fluid Cheers Trevor
