pezmo Posted August 24, 2016 Posted August 24, 2016 I have just acquired my Audi A3 sport, what happens every time pulling away, the central locking will click in and out and the radio will flick on and off, radio will also switch off sometimes when braking. Any ideas?
Audi Owners Club. Posted August 25, 2016 Posted August 25, 2016 Hi Perry...welcome to the Forum! Definitely going to state the obvious here but I would say you have a loose/poor electrical connection somewhere in the system. I would start by checking the fuses and make sure they are secure in the fusebox and remove/replace the ones relating to the central locking and radio. Let us know how you get on with it Cheers, Trevor
pezmo Posted August 25, 2016 Author Posted August 25, 2016 1 hour ago, Trevor said: Hi Perry...welcome to the Forum! Definitely going to state the obvious here but I would say you have a loose/poor electrical connection somewhere in the system. I would start by checking the fuses and make sure they are secure in the fusebox and remove/replace the ones relating to the central locking and radio. Let us know how you get on with it Cheers, Trevor Hi Trev, thanks for the welcome, i'm completely illiterate when it comes to these sort of technology stuff, but i hope its something as simple as that.... thanks
Audi Owners Club. Posted August 25, 2016 Posted August 25, 2016 Loose connections normally show themselves if you switch the radio on and gently move various sections of the wiring or components and see if the radio flickers on/off...then you know what area the fault is in.
pezmo Posted August 25, 2016 Author Posted August 25, 2016 4 minutes ago, pezmo said: Hi Trev, thanks for the welcome, i'm completely illiterate when it comes to these sort of technology stuff, but i hope its something as simple as that.... thanks when i bought the car few weeks ago it was doing it and the owner says it has always done that. Now i had a system put in at some point alll the wires on back of the radio itself was removed and replaced, so i dont think its a connection from the radio.
Audi Owners Club. Posted August 25, 2016 Posted August 25, 2016 Battery connections...loose or corroded terminals?
Magnet Posted August 25, 2016 Posted August 25, 2016 Hello Perry, Not sure I'm understanding this, but am I right in thinking someone, or youself have disturbed the original radio and its connections. If so, I would not agree with your thinking that it cannot be anything to do with that because it has new connections. Crimp connections (if that is what you have) are a real pain unless done properly with the correct crimping tool- and they very often aren't. If these connections have been fiddled with behind the radio and then the radio refitted, it's quite possible that the movement of the wires when fitting it back in, has stressed a connection and that MAY be where your problem lies. Kind regards, Gareth.
pezmo Posted August 25, 2016 Author Posted August 25, 2016 Thanks for that Gareth, i certainly dont think the person i bought the car from had tampered with the radio, and he had said that was happening for a while. but yes i had to remove it when fitting system in....radio even cuts out sometimes sudden breaking.
pezmo Posted August 27, 2016 Author Posted August 27, 2016 will probably have to do that....very annoying the radio cutting in and out !!
pezmo Posted August 30, 2016 Author Posted August 30, 2016 Shocking!!!! Think i may have electrical probs with main electrical system, now front windows intermittently when closing will automatically drop back open about a quarter. Its rare but it happens with both front windows.
Magnet Posted August 31, 2016 Posted August 31, 2016 This car really is doing its best to alert you to the fact that something is wrong and it should be looked at - just like a noise- it will get worse if left unattended to. I think Bengi's advise is sound, and a visit to a reputable auto electrician is needed. Or do you have a good independent within travelling distance? Not sure if these have a body control unit which controls most non engine- management (ECU) functions. This might, again just might, be at fault. Specialist inspection is the order of the day I think. Good luck with sorting it. Gareth.
pezmo Posted August 31, 2016 Author Posted August 31, 2016 Thanks guys....absolutely dreading where this is going!!
