rob1967 Posted August 28, 2016 Posted August 28, 2016 Drivers door not working with remote fob but works with key what can be causing this. Thanks
Audi Owners Club. Posted September 5, 2016 Posted September 5, 2016 Hi Robert....welcome to the Forum. I can only imagine that it is a fault door locking servo motor in the door although I would check there is not a fuse that may control the individual door locks. Otherwise if you lock the doors with the central locking override switch inside the car and if that door locks then it can't be the motor, maybe just a connecting link to the latch mechanism. Let us know how you get on with it Cheers Trevor
rob1967 Posted September 14, 2016 Author Posted September 14, 2016 Hi Trevor sorry for delay Doors lock working with remote sometimes so I am guessing it is micro switch failing. Any other suggestions that it could be Thanks Rob
Audi Owners Club. Posted September 15, 2016 Posted September 15, 2016 Sounds like the microswitches or battery
rob1967 Posted September 19, 2016 Author Posted September 19, 2016 I replaced battery so must be microswitch problem. New lock mechanism needed 1
