Hi all
I took my car to audi to get a diagnostic check done came back as egr valve insufficient flow.
Bought a new siemens EGR valve and I am Still getting the same fault code
The pipe feeding the egr valve has slight oily/sooty coating on the inside which can be wiped off with your finger. No blockages in the pipe.
What else could cause this fault?
2005 Audi A4 2.0Tdi
I would think it may be a sensor fault...gummed up with oil/soot?
Can you by-pass the sensor?
thanks for the reply
Egr delete springs to mind lol
