PoliticalRefugee Posted September 3, 2016 Posted September 3, 2016 Hi, The problem occurred 2 weeks ago, when I put the key in, ESP control shows up and engine cuts off right after it stars plus it gives me a sign of glow plugs/ and oil pressure. After trying to start the car few times it all clears up and allows me to start the car but..... after few hours I got it again and on top of that speedometer and odometer doesnt work as you can see on that second video. Anyone got a clue what can it be ? should I replace instrument cluster or is it a my CAN line faulty ? if so, what can i do whit it ? 1. Startinghttps://youtu.be/n-fZ5ht_Oas2. While drivinghttps://youtu.be/w5yIlzcc8vM1. Starting 2. While driving I also did VAG scan and here are the results : VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 038 906 019 LJ Component: 1,9l R4 EDC G000SG 4910 Coding: 00002 Shop #: WSC 63351 WAUZZZ8E54A161457 AUZ6Z0C0406887 1 Fault Found: 17978 - Engine Start Blocked by Immobilizer P1570 - 35-10 - - - Intermittent Readiness: N/A Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 3429 Coding: 04255 Shop #: WSC 06435 3 Faults Found: 18265 - Load Signal: Error Message from ECU P1857 - 35-00 - - 01317 - Control Module in Instrument Cluster (J285) 49-00 - No Communications Address 08 ------------------------------------------------------- Controller: 8E0 820 043 AA Component: A4 Klimaautomat 1219 Coding: 00000 Shop #: WSC 63351 1 Fault Found: 01794 - Control Module Incorrect Chassis (VIN) Number 35-00 - - Address 09 ------------------------------------------------------- Controller: 8E0 907 279 F Component: int. Lastmodul RDW 0517 Coding: 00001 Shop #: WSC 63351 2 Faults Found: 01312 - Powertrain Data Bus 79-00 - Please Check Fault Codes 01794 - Control Module Incorrect Chassis (VIN) Number 35-00 - - Address 15 ------------------------------------------------------- Controller: 8E0 959 655 J Component: Airbag 8.4EP 1002 Coding: 0010602 Shop #: WSC 01317 1 Fault Found: 00474 - Control Module for Immobilizer 004 - No Signal/Communication Address 16 ------------------------------------------------------- Controller: 8E0 953 549 N Component: Lenks谩ulenmodul 0611 Coding: 00041 Shop #: WSC 63351 1 Fault Found: 01794 - Control Module Incorrect Chassis (VIN) Number 35-00 - - Address 17 ------------------------------------------------------- Controller: 8E0 920 950 M Component: KOMBI+WEGFAHRS. RB4 D42 Coding: 00401 Shop #: WSC 19411 WAUZZZ8E54A艩艩艩 1 Fault Found: 01312 - Powertrain Data Bus 37-00 - Faulty Address 45 ------------------------------------------------------- Controller: 8E0 951 177 Component: Innenraumueberw. 0704 Coding: 00001 Shop #: WSC 00000 No fault code found. Address 46 ------------------------------------------------------- Controller: 8E0 959 433 BC Component: Komfortger谩t T3B 1311 Coding: 06859 Shop #: WSC 63351 4 Faults Found: 00962 - Alarm via. Tilt Sensor 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01561 - Left Rear Door 61-10 - Won't De-Safe - Intermittent Address 56 ------------------------------------------------------- Controller: 8E0 035 186 L Component: concert II GRO 0001 Coding: 01001 Shop #: WSC 63351 No fault code found. End ------------------------------------------------------- Do you know what can it be ?
Audi Owners Club. Posted September 5, 2016 Posted September 5, 2016 Hi Bart You certainly do have a big problem there... I think you may be right with your diagnosis although I would check the aerial receiver for the immobiliser around the ignition switch, wiring and connectors first for any faults and then you may be right with the instrument panel as that is the gateway for the CanBus and any problem there can cause the issues you are experiencing. Let us know how you get on with Cheers Trevor
