hazyfantazy Posted September 5, 2016 Posted September 5, 2016 AUDI A3 TDI 2007 sometimes when cornering a red oil light comes on when i am not sure if this is the oil low warning or oil pressure light it happens intermittently and is accompanied by a beeping warning it can happen at low speed and seems to happen most often when the road turns one way then the other the car has just had a oil service and the oil level is perfect
Audi Owners Club. Posted September 6, 2016 Posted September 6, 2016 Hi Mark I would suggest it is a faulty sensor or wiring connector attached to it. If the oil level is fine and not too thin (washed down with fuel) then it's worth taking a chance on the sensor. I would certainly get it checked sooner than later just in case. Let us know how you get on with it Cheers Trevor
