Chedda88 Posted September 6, 2016 Posted September 6, 2016 As title says. Just purchased a 4.2Q Auto and drivers door is open but the fob is not working at all but if i get in and close the door and use the Lock/Unlock button on the door panel the locks al most double click and wont pop the poppers up... any idea's? The doors wont open even trying the handles from the inside. TIA
Audi Owners Club. Posted September 7, 2016 Posted September 7, 2016 Hi Chris I could only recommend a battery disconnect/reconnect to attempt to reset the system, as doors should unlock if power supply is interrupted....just make sure you have the keys in your hand Let us know when you find the problem as I'm sure someone else may the same issue in the future. Cheers Trevor
