paulo83 Posted September 8, 2016 Posted September 8, 2016 i have a 2002 a6 se with an instrument cluster issue. the speedometer and revs work fine but the battery temp clock is stuck on max, fuel gauge is inaccurate, water temp stuck at 75 degrees and oil temp clock is stuck at 0. anyone have any ideas as to what might be wrong? thanks in advance
Audi Owners Club. Posted September 12, 2016 Posted September 12, 2016 Hi Paul...welcome to the forum I would advise a battery disconnect/reconnect to see if that resets it....just make sure you have all the security codes first. Let us know what you find. Cheers Trevor
paulo83 Posted September 12, 2016 Author Posted September 12, 2016 thanks for the welcome and reply trevor. the battery has already been disconnected and reconnected and didnt make a difference. i was told this was a common problem with audis and could only be fixed by sending it to audi whuich would cost me upwards of £200. any other ideas? thanks again
