paulo83 Posted September 12, 2016 Posted September 12, 2016 anyone know how to programme a key fob for audi a6 2002? thanks in advance
Audi Owners Club. Posted September 13, 2016 Posted September 13, 2016 Usually you will have to programme the infra-red side of things with VAG COM or similar. There is a procedure for resetting after battery replacement which involves pressing the buttons in sequence with the key in the door lock.
paulo83 Posted September 14, 2016 Author Posted September 14, 2016 thanks again trevor ill let you know if that works
amebb Posted May 21, 2019 Posted May 21, 2019 Is there another method on how this can be done? I only have one key for my car. Thank you
Magnet Posted May 21, 2019 Posted May 21, 2019 Hello Paul, Having the original two, but one not currently working, I have tried all methods found inc. using second one in the lock etc. It sounds as if you only have one key/remote and the remote is not working?? Guess you’ve changed the fob battery without success? I’ve resigned myself to having to get this dealer-sorted, but fortunately the ‘spare’ key will unlock and start the car, so no rush on my part. As Trevor says, it sounds like it’s likely to need dealer/ specialist involvement, unless anyone else can help with a magic procedure. Kind regards, Gareth,
