dannyg Posted September 13, 2016 Posted September 13, 2016 Hey guys I know my engine mount has gone on gear box side I'm fixing that at weekend but this really loud crazy noise has come it's when i put foot down engine sounds really loud and if I let off and engine is winding down and I don't know what it is does anyone else would appreciate thanks this is noise in video IMG_3642.MOV
Trevor Posted September 14, 2016 Posted September 14, 2016 I would see if the noise is still there once you have replaced the mount, but I suspect it will be gone
dannyg Posted September 14, 2016 Author Posted September 14, 2016 Thanks Trevor I've never heard a sound like it. A week ago I had the bottom gearbox mount break so the engine was rocking backwards and forwards but I fixed that and it was fine and then last Sunday car felt really rocky again I looked under bonnet and you can rock engine side to side and there's a clicking noise so I knew it was engine mount but then when I was driving home I was in second gear and I let of and there was that noise and it does it in every gear when you let off and when it's on tickover there's no noise but if you Rev car to about 2500 rpm you can hear the vibration
Trevor Posted September 14, 2016 Posted September 14, 2016 Hopefully the new mount should get rid of the noise, if not I could only assume with the excessive engine movement that a joint (intake, exhaust) has been dislodged slightly enough for it to make the sound
