Hi there, im just wondering if anyone can help me?
i have an audi a3 and the indicator on the dash board for rear brake light wont reset even after i have changed the bulb.
any suggestions would be appreciated.
thanks.
Hello Joel,
Can I take it you are referring to the "bulb-out" warning light being still illuminated?
If so, appreciating you may have known that one brake light wasn't working and thought that was the only bulb which had failed, it could, and is most likely to be , that you have another bulb which has actually failed as well.
You really need to do a full lighting check on the car - at dusk is easiest- to make sure all bulbs are lit when they should be. Be careful with rear (tail) light bulbs and don't assume because the light is lit that all is well. Some back lights actually have two tail light bulbs as a fail safe and if one has failed and only one works ( but still lights up the back light) then the warning light will stay on.
Hope some of this helps,
