yaza01 Posted October 14, 2016 Posted October 14, 2016 hi guys i have 02254 interface to generator no signal intermittent and 02479 partial consumer shut off active anyone ever had these codes and can shed any light on whats causing this car starts ok drives fine cheers
Trevor Posted October 17, 2016 Posted October 17, 2016 It would appear that this is a warning that the alternator / battery may be failing. Would check the battery condition first (as it's that time of year where it's getting colder and more consumables are switched on). Ensure you carry out a heavy discharge test on the battery and check the alternator output also. Let us know how you get on with it Cheers Trevor
yaza01 Posted October 21, 2016 Author Posted October 21, 2016 hi thanks for the reply battery is fine how do i test alternator previous owner did replace alternator but how do i test the alternator output
Trevor Posted October 24, 2016 Posted October 24, 2016 If you have a multimeter to hand, place the terminals on the battery and get someone to load up the electrical system by turning all the ancillaries on (air cond, high beams, heated rear screen, etc) that should then load the alternator (e.g. getting it to work hard to send current to the battery to keep it charged) and should produce a reading on the meter of around 14.4 volts. If the meter doesn't change much when the ancillaries are switched on/off then the alternator could be suspect. Check also the battery terminals are clean and secure. Also worth having the battery deep discharge tested by a garage as this will determine if it is on it's way out....it may be fine at the moment but it could be weaker than it should be hence the vehicle sensing it under load.
yaza01 Posted October 25, 2016 Author Posted October 25, 2016 Does this help anyone as current value from battery is jumping from 20.2 to 30a
yaza01 Posted October 25, 2016 Author Posted October 25, 2016 volts on voltmeter are around 13.4 13.8
Trevor Posted November 3, 2016 Posted November 3, 2016 That all looks fine...to be expected if at raised idle with a few ancillaries switched on
VAGtune Posted November 16, 2016 Posted November 16, 2016 Your Voltage regulator is faulty and is not sending DFM signal to BCM which is located in the boot. There is plug on the alternator with blue wire u can test that wire between there and Pin 8 at the rear in the plug that goes into BCM. If continuity is OK then is 100% that your voltage regulator is faulty. Easy job to replace. 1
MrChubba Posted June 11, 2022 Posted June 11, 2022 On 11/16/2016 at 10:48 PM, VAGtune said: Your Voltage regulator is faulty and is not sending DFM signal to BCM which is located in the boot. There is plug on the alternator with blue wire u can test that wire between there and Pin 8 at the rear in the plug that goes into BCM. If continuity is OK then is 100% that your voltage regulator is faulty. Easy job to replace. In situ?
