rscosworth Posted October 16, 2016 Posted October 16, 2016 Good Evening, Recently taken onership of an S3 Saloon, it's a January 2016 car on a 65 plate. It has a few options I believe, B&O but also upgraded Sat Nav, it allows you to draw the letter of the address on top of the dial, think it is called the Technology Pack. The issue we have is that the car didn't have an iPhone cable in, so we asked the dealer to supply. We have now the following cables, none of which seem to be working correctly Yellow Cable, does not detect phone, phone does not detect cable, does not charge, keeps 'Not Connected' under AMI on the Sources menu White Cable, detects phone and charges, shows connected to iPhone 6s on the sources, but does not play any music on the phone, says no compatible media found (or similar words) We also have a 2015 Golf GTI in the family which has a Green Cable, which seems to work ok with the Audi, shows connected and can play tracks from the phone. Is anyone able to advise if the Green cable from Audi is what we need, or are there other cables available for this model? I will go back onto the dealer but would prefer to go armed with some information to ensure I am stating the correct facts. Thanks
Audi Owners Club. Posted October 17, 2016 Posted October 17, 2016 Hi Ross...welcome to the Forum I'm personally not sure about the cabling for the Audi audio systems but I will pin and feature this post so hopefully someone will provide the answer. Let us know how you get on with it. Cheers Trevor
King_Ganymede1980 Posted November 9, 2016 Posted November 9, 2016 Hi Audi gave me their own cable which was coiled like the old phone wire and it works perfect, Audi said it's £42.50 1
rscosworth Posted November 10, 2016 Author Posted November 10, 2016 I think the coiled cable has a USB connector into the car, assuming that's a facelift car then? Mine is pre-facelift and uses a rectangular cable at the car end. I have actually managed to resolve the issue by doing a restore on the phone and using the white collared cable. Thanks 1
