dennis10 Posted October 27, 2016 Posted October 27, 2016 EDIT: Really need this to sell now, can't have her just sitting around - have reduced the price, ideally looking for her to go this weekend, so please make me a sensible offer - somebody will grab a bargain. Beautiful mk1 TT coupe in rare Misano pearlescent red 106k (ish) miles as still in use 53 plate DSG flappy paddle gearbox Full service history MOT September 2017 2 sets of keys Folder full of service history and receipts ** Just for information, as I've been asked a few times - Insurance wise, I'm mid 30s, 9 yrs NCB and I pay £400 with all mods declared! ** -----------------------------------------------------------------Other goodies: Blueflame cat back stainless steel exhaust Revo remap (265-270 hp & around 255 lb.ft) 18" OZ Canyon ST alloys Hubcentric wheel spacers front and back Bose sound system Eibach pro springs and Bilstein dampers Brand new retro-fitted factory cruise control Black half leather interior She is in excellent condition and wants for nothing mechanically. There are 2 massive positives with my car, 1. I have had the timing chains and all associated parts replaced, so unlike many TT's on here she is not an unknown quantity and the chains should be good for the rest of the lifetime of the car. cost - £1400 2. The mechatronic unit has already been replaced (in 2013) in the DSG box, this is another issue that the V6 TT's can suffer from, again this should give some peace of mind for anyone looking to own a V6. (All receipts present) cost - £1800 ----------------------------------------------------------------In the last 6 months: Full service, fully synthetic oil and filter replaced. Haldex earth strap replaced In the last year: Brand new dimpled and grooved MTEC brake discs and Brembo brake pads, front and rear Brand new Vredestein Ultrac Sessanta tyres front and rear Comprehensive suspension and bush refresh including: R32 rear anti roll bar, polybushes & Lemforder drop links Rear adjustable tie arms and polybushes Front wishbone overhaul; cookbots wishbone inserts with polybushes (gets rid of vague steering and alot of understeer), new Lemforder ball joints and the caster increase polybush Front ARB replacement polybushes and Lemforder drop links A full geometry setup at Wheels in Motion - All of this was upwards of £1500 Fitted aftermarket NIME fan controller to rectify blown resistors in the cooling fans (another very common fault on TTs) - fans now work perfectly on all speed settings Also in my ownership: Full timing chain kit fitted, all associated gaskets, seals and bolts (fitted by the very reputable VAG Auto Care services in Lincoln) Have all receipts DSG oil and filter replacement x 2 (2nd time as mech unit cover had developed a small leak, gasket replaced for this) Haldex oil and filter replaced Spark plugs replaced Air filter replaced with K&N performance cone filter Air filter heat shield All other fluids replaced including power steering fluid and coolant Front left steering arm and track rod end DSG Brake switch Pollen filter Coolant temp sensor (another known cuplrit for running issues) Fitted a pair of custom brushed stainless steel cupholders (a previous owner had removed the factory ones) - These are easily unbolted if not to your taste but I love them. Also has a framework in place for holding your phone for sat nav and music (although you'll need to replace the holder with either a generic bracket or one specifically for your phone, mine is a Sony Z3 compact) Sony Bluetooth stereo all wired upto the excellent factory Bose amp and sub Brand new factory Audi cruise control fitted by myself including brand new indicator stalk and extra loom going to ECU -------------------------------------------------------------------------------------------------- Some minor points on an otherwise fantastic car: A few stone chips and age related marks around the body, no dents. Otherwise the paintwork is in extremely good condition for 13 years old and is the best colour I've ever seen on a car. In the sunlight, the two-tone red/orange pearlescent paint is a work of art! A bit of kerbing on a couple of the alloys, nothing really bad, they still look excellent when clean. The headlamp washers don't work (another well known issue with TT's) So far I've not had an issue come MOT time, but they aren't complicated or expensive to fix, I just never use them so haven't bothered to sort them out. When you hold it on full lock the power steering can squeal a bit - it has been checked for fluid level and works perfectly, apparently a VAG feature, it was the same on my Golf GTI Occasionally the traction control will activate on the front left wheel when going around a tight-ish right hand bend. This has only started happening since an alignment and the track rod end was replaced at a garage, so I suspect either an ABS sensor has been upset, or the tracking is slightly out. If you disable the ESP via the button or permanently disable in VCDS, it drives perfectly and there are no fault codes or errors indicating anything else. - I have bought a brand new ABS sensor for that side that can go with the car when it sells. ---------------------------------------------------------------------------- That's about all I can think for now - as you can imagine, she is an extremely well looked after car. The engine is astonishing, will happily pull itself along at around 28mph in 6th gear on cruise control and pull hard all the way up the rev range with no dip in torque or power like a turbo car can suffer. She uses no oil or water and will be an excellent buy for an enthusiast or somebody looking to get into sports car ownership. As an added bonus, I also have VCDS on my laptop and a diagnostics cable so am happy to show the prospective buyer the timing chain readings and run a diagnostic fault scan for peace of mind. Car is available to view in Northwood, HA6 Price: £4950 Contact Simon: 075(three)0 772(zero)66
dennis10 Posted November 3, 2016 Author Posted November 3, 2016 EDIT: Really need this to sell now, can't have her just sitting around - have reduced the price, ideally looking for her to go this weekend, so please make me a sensible offer - somebody will grab a bargain.
