Beachie Posted November 14, 2016 Posted November 14, 2016 Hi. I have an A6 C6 Avant 2.0 tdi manual. I have a problem at around just under 2000 rpm, where the car seams to kangaroo but very quickly, almost like the brakes are being applied at about five times a second. It's more noticeable in lower gears and does not happen all the time but does seem to be getting worse. When it does this there seems to be a 'chirping' sound coming from possible the engine or the front of the car. It feels as if it's engine related as when you push through it, normality resumes. Anyone come across this or have any ideas? I have had the car about six weeks but I noticed it about four weeks ago.
Audi Owners Club. Posted November 15, 2016 Posted November 15, 2016 Hi David It could be a split/hole in the turbo intercooler hose if its making a chirping noise which could also give the same symptoms as the turbo would be boosting around that rpm. Worth taking off the hose to inspect it for damage. Let us know how you get on with it Cheers Trevor
