I'm trying to fit a Space Saver Spare Wheel into the boot/trunk space under the removable floor. however, I'm having difficulty removing the Styrofoam liner, the large one. The smaller one can be removed with a little jostling but the larger one seems to be fixed under some of the trim. Has anyone else tried to do this successfully without destroying the Styrofoam tray and if so how?
  • 3 weeks later...
Many thanks to all who replied it really helped, your concise instructions were invaluable.
On 28/12/2016 at 0:07 PM, Trevor said:
Sorry no one answered your post but its probably just a case of no one encountering the same problem.
Did you sort it in the end?
Yes I did thank you.
