Marc cain Posted December 11, 2016 Posted December 11, 2016 Just had my 2004 1.8t service and oil pressure warning comes on when driving at speed can anyone help me with this thanks
Magnet Posted December 12, 2016 Posted December 12, 2016 Hello Marc, I think you are being wise in questioning this issue, since the consequence of actual low oil pressure can be serious. Perhaps it would be useful to have some basic information, and as simple as it may sound, confirmation that the oil is up to the required level. Yes, a bit basic, but you cannot ignore the fact that not enough oil was put in, or indeed there isn't an oil leak at the filter, drain plug or somewhere else. You will also need to know what grade if oil has been used and to let us know what mileage this engine has done. All things being equal, it could - just could - be as simple as a suspect oil pressure switch, but your really do need to get the actual oil pressure measured with a gauge to know exactly where you are with this. Assuming correct oil level and grade, no leaks, then I think there is some urgency in getting the actual pressure checked. Hope some of this helps and you are able to let us know. Good luck with it. Kind regards, Gareth. 1
Audi Owners Club. Posted December 12, 2016 Posted December 12, 2016 Hi Marc...welcome to the Forum I would strongly advise (as has Gareth already) to get the car to a garage as soon as possible as there is a known fault with oil pumps failing on some of the Audi petrol engines. Keep us updated with how it is going. Cheers Trevor
