nellyboy__ Posted December 13, 2016 Posted December 13, 2016 Hi, I've attached a video - so I won't explain exhaustively. I'm not sure if the car is showing the symbols to tell me about issues or whether it just lists through all the checks showing what it is doing. The manual says if there are issues there will be a 'chime' and text showing on the display explaining the fault - neither of these things happened. The start of the vid is me pressing 'check'. The car only has the ignition on, but process was the same with the engine running. Would really appreciate your help. 2007 A6 Allroad IMG_1196.MOV
Audi Owners Club. Posted December 13, 2016 Posted December 13, 2016 Hi Nelly...welcome to the Forum It would seem that you are running through the warning lamp system to ensure that they are working correctly. I don't see that you have any issues there. Cheers Trevor 2
nellyboy__ Posted December 13, 2016 Author Posted December 13, 2016 Trevor - I really appreciate your reassurance. I'm new to Audi, so would be lost otherwise. 1
Brad-B5 Posted January 10, 2017 Posted January 10, 2017 @nellyboy__ What Trevor said, it's this system that just runs through the things, (more of a reassurance thing) that Audi put in place :) if there is an Issue with the car a symbol will pop up and stay on at all times. if unsure run a diagnostics on the car ;) Bradley 1
