I have a issue with headlamps right side not working atoll even indicator, left side only have one lamp working also some interior lights not working. Any ideas?
Thanks!
IMG_7402.MOV
Hi and welcome to the Forum
Wow, you do seem to have a few faults...including what looks like an engine management fault.
The first place I would start is with checking the bulbs and connections, then move onto the fuses.
Alternatively, there could be issues with the wiring but start with the simple stuff first.
Also, make sure that the correct bulbs have been fitted in the first place as wrong bulbs can backfeed other ones in the system and bring up faults elsewhere.
Cheers  Trevor
