potatopotato Posted January 8, 2017 Posted January 8, 2017 Hi all, Our 1.9 TDi has a habit of taking a few more turns than usual when starting after being driven recently, so when warm. It does eventually fire but nearly takes the engine mount with it and makes a hell of a noise (IMO, probably being dramatic). I had an old E34 BMW that wouldn't start at all from hot due to the heat melting a connection in the starter solenoid so I'm inclined to change the starter on the A3 and be done with it. However is this a problem anyone else has experienced and fixed a different way? Mike.
Audi Owners Club. Posted January 9, 2017 Posted January 9, 2017 It doesn't sound like the starter motor if its turning the engine over (at a constant speed) or even the battery. However, if its turning over at a slower speed then it could be the battery, starter or even wiring at fault. Other areas to consider are fuel filter; loss of pressure within the filter head, immobiliser, etc May be worth running a scan on it if you cannot find anything wrong with the battery or starter. Keep us updated on this one Cheers Trevor
Magnet Posted January 9, 2017 Posted January 9, 2017 Hello Michael, I too would be tending to discount the battery and indeed the starter motor since you say it appears to start OK from cold when there would be a far greater load on these components. Of course, it's always difficult to diagnose these problems, but it could (just could) be an injector/s at fault and perhaps giving you symptoms of "misfire". As I understand it, even one faulty injector can have a significant influence on how it starts and runs. Not sure if this would show up on the diagnostics, but failing that it would be a question of having a leak- back test on them, and if any issues, taking them out and having them checked - not too expensive to have them checked. Good luck with sorting it. Kind regards, Gareth. 1
