Russhunt Posted February 2, 2017 Posted February 2, 2017 Hi all, I've got an issue with my air conditioning running all the time, the switch/button for all 3 of air con/ rear heated window and air recirculating don't illuminate so I can't tell if their actually on, also no lights for the blower dials, any suggestions please. Audi A3 TDI 2.0 sportback 2008
Brad-B5 Posted February 2, 2017 Posted February 2, 2017 Hi Russell Welcome to the forum! Either a loose wire or that whole unit is on the way out/gone. when did it start going funny? Regards Bradley
Russhunt Posted February 2, 2017 Author Posted February 2, 2017 Hi Bradley, Thanks The past couple of days since I had another issue with my rear tail light, resolved that water getting in the casing, do you mean a loose wire to the unit itself, is it possible to remove the unit?
Brad-B5 Posted February 3, 2017 Posted February 3, 2017 Glad you got your tail light fixed! :) and yes in the unit itself, you should be able to use a tool of some sort to get it out but looking online I found this.. From online " The surround of your hazards buttons ect if you have double din just unclips off and then pull the climate unit down and forward at same time with a little force and will just come out easy as that" I hope this helps Bradley
Audi Owners Club. Posted February 6, 2017 Posted February 6, 2017 Hi Russell....welcome to the Forum Sounds like the panel has gone faulty as Bradley has suggested....keep us updated on this as would like to know the outcome. Cheers Trevor
