Russ1201 Posted February 7, 2017 Posted February 7, 2017 Hi all have noticed on my Audi that the cooling fans on the radiator stay on after ignition is switched off it does turn off after a few minutes but it never used to happen the engine is reading warm and the water in the reservoir is warm to touch ..... any ideas anyone
Magnet Posted February 8, 2017 Posted February 8, 2017 Hello Russ, When you say warm, does the car still get up to normal operating temperature as quickly as it should, and not exceed normal on the gauge. We would need to know this before offering meaningful advice. Kind regards, Gareth. 1
Audi Owners Club. Posted February 8, 2017 Posted February 8, 2017 Hi Russ....welcome to the Forum As Gareth has mentioned about the operating temperature, I would ask when it started to happen and did anything affect it (work carried out, etc) Also, is the Air Con switched off as this has a seperate fan, so it could be the system finishing off the recirculation and shutting down, etc. Cheers Trevor 1
Russ1201 Posted February 8, 2017 Author Posted February 8, 2017 Hi guys and thanks for the welcome .... yeah car reaches normal operating temperature and doesn't boil up sits at 90 degrees and the water in the reservoir isn't hot hot just warm ........ it started when I blew a fuse for the interior light I replaced the fuse went for a small drive about ten miles and could hear the cooling fans running .... the air con is switched off also ..... someone mentioned maybe dpf regeneration bit don't think mine has that function kind regards Russ
Audi Owners Club. Posted February 8, 2017 Posted February 8, 2017 It should have DPF as its new enough. Coincidence with it happening when the fuse blew though??? What blew the fuse initially?
Russ1201 Posted February 8, 2017 Author Posted February 8, 2017 Don't laugh .... I was putting a led festoon bulb in but it blew the fuse ...... it's a 60 plate 2 liter tdi
Audi Owners Club. Posted February 8, 2017 Posted February 8, 2017 oops! it obviously didn't like that then. I'm wondering if the two things are related then...worth having a scan to see if there's anything amiss with the CanBus system
Russ1201 Posted February 8, 2017 Author Posted February 8, 2017 Do you mean the warning check on the dash board trevor ???
Audi Owners Club. Posted February 8, 2017 Posted February 8, 2017 No, I meant more of a scan on a diagnostic machine (VagCom or similar) which should give you fault codes in the ECU memory of events and components failing, etc. You can pick up software and a connection lead on eBay or pop into a VW Audi specialist garage who can scan the car for not a lot of money.
Russ1201 Posted February 8, 2017 Author Posted February 8, 2017 Drove home tonight all ok no fans running ....... 2
