So I have an Audi A3 2.0 tdi s line 2006 which needs a new drive shaft and cv joints fitted. This looks within my capabilitys.
Is is there any special tools I need to do this? Can someone list what I may need?
Thanks
It should be a straight forward except you may need a balljoint separator (or large hammer) and a few prybars.
Otherwise, just ordinary hand tools, trolley jack, axle stands, etc
Okay thanks for the reply. Do you know what I need to undo the 6 bolts that attaches the cv joint to driveshaft? Want to make sure I have the right bit for this evening
Yes, they will need to come out to remove the driveshaft in one piece...try not to pull the joint apart (bearings will go everywhere)
I have just finished removing the old drive shaft and fitting the new one.. wasnt actually too bad - a little fiddly but okay. Took me 3 hours but a lot of that was hunting for correct tools!!
pleased to say the shuddering has now gone! I'm so relieved! The inside cv joint was absolutely shagged!
Thanks everyone for your help!
I'm glad it worked out well. The only note of caution is that if one side was worn out, the other won't be far behind, but at least you now know how straightforward the job is.
