curlykevs Posted March 1, 2017 Posted March 1, 2017 hello to everyone on here i am new on here and need help with my air suspension front drivers side goes up when pump is on but goes down as soon as pump stops i have changed the level sensor and tried to re calibrate with vagcom i go through all the stages save channel 5 the i get no response from control module sso nothing is changed it still goes down on drivers side only fault coming up is pump stop due to over temp put new pump on still the same 2010 Q7 all hep gratefully received thanks
Audi Owners Club. Posted March 2, 2017 Posted March 2, 2017 Hi Kev...welcome to the Forum Sounds like a leak in the air suspension Here is a link to some available parts http://www.audiownersclub.com/parts-results/Q7/Air-Suspension--Parts/174088 Let us know what you find Cheers Trevor
curlykevs Posted March 3, 2017 Author Posted March 3, 2017 hi i changed the suspension air bag and now i get this message from vagcom
Bigdave1230 Posted March 4, 2017 Posted March 4, 2017 Sounds like a valve stuck open. If the bag had such a big leak that it goes down straight away when the pump stops then I doubt it would lift it up in the first place. The over temp fault is just because the pump keeps kicking in. Unless it's really noisy it should be fine. There is a valve block just behind the pump that might be stuck but check the individual valve on the strut first with soapy water to see where the air is escaping. What have you changed to get vagcom to say that. Have you changed the bag and now it's stuck down on the corner and won't raise the car at all? If so jack the car up on that wheel to take some weight off and see if it will raise it up.
curlykevs Posted March 5, 2017 Author Posted March 5, 2017 On 01/03/2017 at 3:31 PM, curlykevs said: hello to everyone on here i am new on here and need help with my air suspension front drivers side goes up when pump is on but goes down as soon as pump stops i have changed the level sensor and tried to re calibrate with vagcom i go through all the stages save channel 5 the i get no response from control module sso nothing is changed it still goes down on drivers side only fault coming up is pump stop due to over temp put new pump on still the same 2010 Q7 all hep gratefully received thanks i now keep getting invalid when i do put in measurement in channel 4 all others channels ok but channel 4 invalid and then channel 5 says error
Bigdave1230 Posted March 6, 2017 Posted March 6, 2017 Channel 4 is the rear right I think and 5 is just to confirm the values so probably will say error if there isn't any value in 4. Have you entered anything for 1,2,3? What value are you entering in channel 4. Is any of the suspension lower than the rest. I think the test conditions are that the engine has to be running and all the doors are closed
Bigdave1230 Posted March 6, 2017 Posted March 6, 2017 http://www.ross-tech.com/vag-com/cars/levelcontrol.html This might help 👍🏻
curlykevs Posted March 6, 2017 Author Posted March 6, 2017 18 minutes ago, Bigdave1230 said: http://www.ross-tech.com/vag-com/cars/levelcontrol.html This might help 👍🏻 hi yes set height for 123 but 4 says invalid so cant set 5 drivers side lower than right side
Bigdave1230 Posted March 6, 2017 Posted March 6, 2017 Is it Left Hand Drive? Is just one corner down or both on that side. What is the value you are trying to enter? Is the mmi greyed out on the suspension settings? What parts have you changed on the car to get to this stage?
curlykevs Posted March 6, 2017 Author Posted March 6, 2017 49 minutes ago, Bigdave1230 said: Is it Left Hand Drive? Is just one corner down or both on that side. What is the value you are trying to enter? Is the mmi greyed out on the suspension settings? What parts have you changed on the car to get to this stage? hi it is right hand drive it is higher on passenger side 123 set ok 4 wont take it is at 410 i have tried taking it up 20mm says invalid so tried 15 still same tried 10 still same mmi is on automatic only no other settings changed front bag it is now better but cant set untill i get channel 4 sorted
Bigdave1230 Posted March 6, 2017 Posted March 6, 2017 Hi what are the levels for all four channels and what are the stored values for all four channels? I think if the stored value for example is 495 and the actual value is 410 then the ecu won't allow such a dramatic change and so you will need to set it to within 20 of the stored value until you can get to where it is.
curlykevs Posted March 6, 2017 Author Posted March 6, 2017 5 hours ago, curlykevs said: hi it is right hand drive it is higher on passenger side 123 set ok 4 wont take it is at 410 i have tried taking it up 20mm says invalid so tried 15 still same tried 10 still same mmi is on automatic only no other settings changed front bag it is now better but cant set untill i get channel 4 sorted still getting no response from controller after getting all 4 valid but tried 20 times at least no response from controller
curlykevs Posted March 6, 2017 Author Posted March 6, 2017 24 minutes ago, curlykevs said: still getting no response from controller after getting all 4 valid but tried 20 times at least no response from controller got all 4 channels valid and tested and saved channel 5 tested and save but every time it says no response from controller so will only on automatic all others greyed out
Bigdave1230 Posted March 6, 2017 Posted March 6, 2017 Is it a genuine cable you are using to program. If you do vcds options test what does it say.
curlykevs Posted March 7, 2017 Author Posted March 7, 2017 22 hours ago, Bigdave1230 said: Is it a genuine cable you are using to program. If you do vcds options test what does it say. yes genuine cable vcds now getting channel 4 invalid so now cant set 5
Bigdave1230 Posted March 9, 2017 Posted March 9, 2017 What does vcds - options - test say. You can ring Rosstec for support who will talk you through some things to see why it's not talking but to be honest I'd probably ring Audi and pay £80 or something to get them to do it on there computer if it's gone on this long. I've only seen something like the problem your having when my mate bought a Mickey Mouse lead from eBay when his original one broke
