Hi, wonder if anybody could help.
Have an 2004 audi a3 2.0 tdi tiptronic.
Have some problems..  on start up it needs cranking over a bit, (could deal with this) however when driving it the other day left the house fine pulled over at the shop went in come out started car up put in drive and went to pull off and no revs or acceleration.. Turned the car off and on again still nothing...  Then off we go (about a minute) get going along again stop at the roundabout same thing again..  However when this happens I lose all revs it drops to about 800rpm.  When it eventually goes back to 1000rpm it seems to go OK. Seem to have like an engine cough occasionally Aswell. Have plugged in vcds and nothing obvious comes up... Any ideas before I start throwing money into it.???  Tia
It could be dozens of things causing the fault Tally. Rather than wildly guess at it and send you on many wild goose chases, you would be better advised to have the problem analysed by someone with the right equipment. It would be cheaper in the end.
I have plugged it into vag.com and it shows no codes. So basically no body knows where to start not even main dealer...  Thought I would see if anyone had the same issue and to give a place to start.
OK all you can do is work your way through all the possibilities, but that could take a lot of time and effort. Start by looking at the obvious things like air filter, fuel pump & injectors.
Hi Tally
I agree with cliffcoggin the list is endless as to where to start....however, the first place I would start is with the throttle sensor but to check this you would need live data running on the VCDS. This should show a linear reading from closed throttle to fully open with no glitches. If the reading does not change then there's your problem.
After that I would try measuring fuel pressure and see if there is a problem there.
Good luck and let us know what you find
Cheers   Trevor
Hi sorry to be a pain do you happen to know what measuring block we should be looking at for fuel pressure?
and I have also checked the Throttle position sensor and it seems to be fine from 0-100%, have also changed brake light switch from behind the peddle just in case and no change
Thank you
sorry, not sure about the measuring block...I normally use a Snap-On scanner and look at live data for what's occurring when the fault happens to see what is going on.
Tuesday,21,March,2017,09:31:30:06598
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.2.0 (x64)
Data version: 20170107 DS267.0
www.Ross-Tech.com
VIN: WAUZZZ8P44A106614   License Plate: AUDI A TURBO
Mileage: 201460km-125181mi   Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8P44A106614   Mileage: 201460km-125181miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 1010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 016 AT    HW: 028 101 145 3
   Component: R4 2,0L EDC G000AG  5689
   Revision: 12345678    Serial number: AUX7Z0C9FNQ019
   Coding: 0000078
   Shop #: WSC 06435 000 00000
   VCID: 75E1EE931CD8F0E9C0-8020
2 Faults Found:
16618 - Boost Pressure Regulation
            P0234 - 000 - Limit Exceeded (Overboost Condition)
             Freeze Frame:
                    RPM: 2394 /min
                    Torque: 278.0 Nm
                    Speed: 94.0 km/h
                    Load: 72.9 %
                    Voltage: 14.36 V
                    Bin. Bits: 10101100
                    Absolute Pres.: 2213.4 mbar
                    Absolute Pres.: 2590.8 mbar
16785 - EGR System
            P0401 - 000 - Insufficient Flow
             Freeze Frame:
Readiness: 1 1 0 0 0
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 041 C    HW: 02E 927 770 G
   Component: GSG DSG             0623
   Revision: 02100224    Serial number: 00000310270092
   Coding: 0000020
   VCID: 122BB50F0D7647D145-8046
No fault code found.
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0103
   Coding: 0023174
   VCID: 3A7B3DAF75465F91ED-806E
Address 08: Auto HVAC        Labels: 8P0-820-043.lbl
   Part No SW: 8P0 820 043 F    HW: 8P0 820 043 F
   Component: KlimavollautomatH12 0150
   Revision: 001354      Serial number: 8P0820043F
   Shop #: WSC 00000 000 00000
   VCID: 2F6D1CFBBE048A394A-807A
1 Fault Found:
00797 - Sunlight Photo Sensor (G107)
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 3
                    Fault Frequency: 254
                    Reset counter: 181
                    Mileage: 150182 km
                    Time Indication: 0
                    Date: 2013.11.16
                    Time: 08:10:16
             Freeze Frame:
Address 09: Cent. Elect.        Labels: 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 A    HW: 8P0 907 279 A*
   Component: Bordnetz-SG 1.0 H29 0501
   Revision: 00029000    Serial number: 00000000190054
   Coding: 01884F00A2141000000000000000000000
   VCID: 3B7538AB7A7C6699F6-806E
   Subsystem 1 - Part No: 8P2 955 119 C  Labels: 1TX-955-119.CLB
   Component: Wischer WWS Audi350 0180
   Coding: 16711696
   Shop #: WSC 00000
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
            004 - No Signal/Communication - Intermittent
Address 15: Airbags        Labels: 8P0-959-655-84.lbl
   Part No SW: 8P0 959 655 F    HW: 8P0 959 655 F
   Component: Airbag 8.4ED    H01 0130
   Coding: 0011602
   VCID: 45815E530CB8206990-8010
Address 16: Steering wheel        Labels: 8P0-953-549.lbl
   Part No SW: 8P0 953 549     HW: 8P0 953 549
   Component: Lenksäulenmodul H10 0020
   Coding: 0011142
   VCID: 7BF5F8AB3AFCA699B6-802E
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: Lenkradmodul    H02 0030
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY7.lbl
   Part No SW: 8P0 920 980 H    HW: 8P0 920 980 H
   Component: KOMBIINSTR. VDO H25 0110
   Revision: D07         Serial number: 2249CD07001680
   Coding: 0000403
   Shop #: WSC 00999 067 57207
   VCID: 3C773BB77F7261A1FF-8068
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 B    HW: 1K0 907 951
   Component: Gateway         H08 0090
   Revision: 08          Serial number: 240010390642E6
   Coding: 3F0F0B42070101
   VCID: 2643F9DF91FECB71B9-8072
1 Fault Found:
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 216
                    Time Indication: 0
                    Date: 2017.03.16
                    Time: 10:58:22
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Revision: D07         Serial number: AUX7Z0C9FNQ019
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN1.lbl
   Part No: 8P0 959 801 A
   Component: Tuersteuerger.  H10 0010
   Coding: 0000048
   VCID: 397922A370405489E4-806C
2 Faults Found:
00913 - Window Regulator Switch; Front Right Driver (E81)
            008 - Implausible Signal - Intermittent
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 E
   Component: EPS_ZFLS Kl.10      1202
   VCID: 2E5301FFB90E833141-807A
1 Fault Found:
02441 - Yellow Malfunction Lamp in Instrument Cluster
            013 - Check DTC Memory - Intermittent
             Freeze Frame:
                    Mileage: 1440 km
                    Temperature: 8.0°C
                    Voltage: 12.00 V
                    Voltage: 11.90 V
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433
   Component:    KSG          H02 0040
   Coding: 008800186D288505485AC63000
   VCID: 79F9E2A330C09489A4-802C
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Part No: 1K0 907 719
   Component: Neigungssensor  002 0002
   Subsystem 3 - Part No: 8P0 951 177
   Component: Innenraumueberw.H03 0010
1 Fault Found:
01134 - Alarm Horn (H12)
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P3 035 382     HW: 8P3 035 382
   Component: AB2 SUBWOOFERBOXH23 0100
   Revision: 00001       Serial number: 10000001083065
   VCID: 70EFDF8763BAD5C113-8024
2 Faults Found:
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 199
                    Mileage: 200738 km
                    Time Indication: 0
                    Date: 2063.15.31
                    Time: 31:63:63
             Freeze Frame:
                    Temperature: 5.0°C
                    Raw, Form. N/A: 000 000 000
00446 - Function Limitation due to Under-Voltage
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 2
                    Reset counter: 199
                    Mileage: 200738 km
                    Time Indication: 0
                    Date: 2063.15.31
                    Time: 31:63:63
             Freeze Frame:
                    Temperature: 5.0°C
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN1.lbl
   Part No: 8P0 959 802 A
   Coding: 0000048
1 Fault Found:
Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
   Part No SW: 8P0 035 195     HW: 8P0 035 195
   Component: symphony II EU  H55 0400
   Revision:      19S    Serial number: AUZ5Z4C5339060
   Coding: 0001001
   Shop #: WSC 00539 210 08758
   VCID: 6FEDDCFB7E84CA390A-803A
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 C    HW: 1K0 963 235 C
   Component: PTC-Element         0404
   Revision: 00600000    Serial number:
   VCID: 2B5508EB8A1CF61966-807E
End-------------------------(Elapsed Time: 01:50)--------------------------
OMG =O Had my turbo veins changed as this was also an issue. Also had EGR valve deleted (which is one of the codes) But an y idea what the others could be ... really starting to lose hope with this car now and kinda wishing i didnt go for an audi and stuck with my manual golf =(
Until I read that you had the turbo vanes replaced and the EGR deleted, these were going to be my conclusion.
Were all the codes been erased after fitting turbo cartridge and the EGR delete?  If not, these are prior to the faults you are experiencing.
The only other thing I can note from the list is that the Battery voltage went low...if this is not a one-off then maybe it could be related to the running fault?
