I've got wind deflectors but not yet fitted so will buy this most likely to make the installation easier
Ah okay, its just peal off the sticky bit then clip them in isn't it.
yes pretty much and then using the clips to hold them in place.
I closed the windows as soon as possible so they sat in their natural position but otherwise, easy peasy to fit.
....and they certainly work well compared to the gale force winds that were coming in before
.....oh and they certainly enhance the look of any car as well  :-)
Have a set of heko in my room but need to find the right weather and when i can be bothered to do it lol, you don't need the clips though do you, only if the windows don't go all the way up, but can't wait to fit them lol
The clips are there to retain the deflectors while they bond but I left mine in there but did notice they would pop out and disappear after a while.
But if you put the windows up, they should retain them in position.
Just make sure the door/window frame area is not full of gunge and they should bond nicely
