Jordan95 Posted March 27, 2017 Posted March 27, 2017 Anyone got a guide or the knowledge to tell me step by step of moving a ko3 turbo from a3 2.0 tfsi 2006 Quattro?
Audi Owners Club. Posted March 27, 2017 Posted March 27, 2017 It's pretty straight forward with just hand tools and following a procedure when fitting new one to prime up before running the engine. Just make sure you block up pipes and hoses with rag to avoid getting grit, dirt, nuts & bolts being ingested when removing and refitting. Good luck!
Jordan95 Posted March 27, 2017 Author Posted March 27, 2017 Cheers trevor, any chance you could tell me step by step?
Audi Owners Club. Posted March 28, 2017 Posted March 28, 2017 No need really....just a case of undoing nuts and bolts until it comes off and then the reverse to refit. Only take care with the ingress of dirt and make sure you prime it first
Tonyh92 Posted April 14, 2020 Posted April 14, 2020 I have a 2005 audi a3 2.0 tdi quattro have i to drop out the engine to replace the turbo if not could some step by step tell me how to get it done if the engine doesnt need removed. Thanks
Steve Q Posted April 14, 2020 Posted April 14, 2020 3 hours ago, Tonyh92 said: I have a 2005 audi a3 2.0 tdi quattro have i to drop out the engine to replace the turbo if not could some step by step tell me how to get it done if the engine doesnt need removed. Thanks Two ways. First is to remove the exhaust and then take the turbo out between the subframe and the body. Or you can take it off from above. Here's the workshop manual to remove it: https://workshop-manuals.com/audi/a3_mk2/power_unit/4-cylinder_tdi_unit_injector_engine_(2.0_ltr._4-valve)_mechanics/exhaust_turbocharger_g-charger/turbocharger_and_charge_air_cooling_vehicles_with_engine_codes_azv_bkd/removing_and_installing_turbocharger/ It's step by step and hope it helps 🙂 Cheers Steve
