Tipp Posted April 8, 2017 Share Posted April 8, 2017 Looking for any info please. 2007 Audi A6 2L diesel automatic when starting there is a vibration for 2/3 seconds then it's gone has anyone an idea? No noise from engine or lights on in the dash otherwise drives fine. Quote Link to comment Share on other sites More sharing options...
Brad-B5 Posted April 10, 2017 Share Posted April 10, 2017 Hi Shay Is it a light judder or a violent judder? does it make your take off slower? Regards Bradley Quote Link to comment Share on other sites More sharing options...
Tipp Posted April 10, 2017 Author Share Posted April 10, 2017 Hi Brad no only very slight for 2 seconds when starting but when you start from cold there is nothing and it drives fine any help much appreciated thanks. Quote Link to comment Share on other sites More sharing options...
Brad-B5 Posted April 11, 2017 Share Posted April 11, 2017 When was the clutch last changed and how many miles has your car got? Regards Bradley Quote Link to comment Share on other sites More sharing options...
Tipp Posted April 11, 2017 Author Share Posted April 11, 2017 The car is automatic and I only changed gear box oil last week. 270km on it. Quote Link to comment Share on other sites More sharing options...
Magnet Posted April 11, 2017 Share Posted April 11, 2017 Hello Shay, So we know it's OK starting from cold but shudders for a couple of seconds when started from hot. Now if it's only a couple of seconds of shudder then I guess the car has barely been put into Drive and this shudder must simply be when the engine ticks over for those seconds. Is this right? If so, is there any associated smoke? - you will probably need an assistant to check this. A stab at this while you come back with some more detail ( and depending if I'm understanding it correctly) would be to think about having the injectors checked. Perhaps the simple leak back test to start. Kind regards, Gareth. Quote Link to comment Share on other sites More sharing options...
niedzial1983 Posted April 24, 2017 Share Posted April 24, 2017 Sounds like a engine or gearbox mount is failing Quote Link to comment Share on other sites More sharing options...
