liampunkdaft Posted April 28, 2017 Posted April 28, 2017 Hi Guys, When I purchased my A4, 6 weeks ago I got a platinum warranty from warranty wise with it, from the dealer. I thought to be on the safe side id get it in to a local VAG Specialist for a health check to make sure everything was ok. I have noticed since I got it when at idle and usually after the car has warmed up there was what sound's like little knocks every so often. Ive had the bonnet open to listen to see if I can hear where its coming from and couldn't source it. Local Vag specialist done the health check today to recommend DSG gearbox further inspection needed and when I spoke to the tech he suggested it could be a flywheel, its supposedly really common. He said he road tested the car and it drove fine although he said the car should be more responsive in D and its something that could possibly go a couple of years before a fault occurs. I obviously have this warranty for another 4 and bit months do you think I should contact them to get this looked at and do you think will they entertain me when I speak to them? Thanks, Liam
Audi Owners Club. Posted May 3, 2017 Posted May 3, 2017 I would definitely log the fault with the warranty company now so that if it goes in the future then at least it was mentioned. Hopefully they'll give the go-ahead if its a common fault.
