I have a3 8v 5 door hatch 2.0 tdi se,it has halogen lights,i want to upgrade it to front exon and dynamic sweeping rear tail lights.
I have sourced the front exon headlights along with a set of rear dynamic taillights.
who is the best person to connect these to the car and do a little coding.
I'm in central Scotland, After speaking with ash,audi-retrofit London,I was told to get part ONBOARD SUPPLY CONTROL UNIT 5Q0 937 084 AE
So I have all the bits needed,just looking for someone a bit more local than going to London to have this done.
Thanks in advance
  • 3 months later...
Drop me a line based in lancashire, do you have all the wiring looms etc ?
May be better if you could send me chassis num and i can work out what you need, are you headlights a matching pair ? need the part number of them also.
You will need to do CP on your new modules i have all the machinery for this.
Hi thanks ive had it all done for a good price,got matching front led and rear dynamics had the led module fitted inside the car wiring looms put on and all works and looks great
Hey machine 3006 ! I'm trying to do the same to my audi ! what is required I have got the front and back headlights and I have got a loom wire for the front what else will I need ? would i need a look wire for the back too ?
  • 2 years later...
Hey mate could you message me regarding retrofit lights please
