Ian81 Posted May 21, 2017 Share Posted May 21, 2017 Hi today my rear doors won't open using the bottoms on my key, they will open from the inside handles and once opened they will open from the exterior handles and will lock from the key again, any one got an idea wat the fault is Quote Link to comment Share on other sites More sharing options...
Bear777 Posted June 9, 2017 Share Posted June 9, 2017 Oh dear. I feel for you as I've just had this on mine. Seems to be one of many common faults on Audi's across a number of years. What appears to happen is one of the two motors of the central locking system in that particular door go faulty. You will need to remove the door card, get inside the door and pull the central locking unit out from that door (white). Once you've disconnected it and all of it's cables you need to take it apart, find the motors, pull them apart and blow out all of the carbon inside. Then re-assemble them and clean the contact with WD40 before reseating them and reassembling the door lock. The alternative is to buy a new door lock (~£100). I should point out that many people have come across similar problems and they have not always had the same solution to their problems. But for mine this happened with both the drivers and rear passenger doors. I did have a link for removal of the door card and lock somewhere - if you Google it it should come up. Good luck Quote Link to comment Share on other sites More sharing options...
