The_WTBM Posted May 24, 2017 Posted May 24, 2017 went to buy new brake discs the other day and i find out that after putting my reg plate in 3 different sizes came up. my car = Audi a6 Avant 2010 2.0TDI 170bhp Lemans spec just wondered if there was a way of telling with out taking the disc off and checking cheers
Audi Owners Club. Posted May 25, 2017 Posted May 25, 2017 Sometimes you can see it stamped into the outside edge of the disc otherwise its a case of taking the wheel off and measuring it up
The_WTBM Posted May 26, 2017 Author Posted May 26, 2017 ok cheers they aint stamped so off they will have to come
Hoggy1972 Posted May 28, 2017 Posted May 28, 2017 I just did my fronts this week. If you look on the chassis label either in the boot by the spare wheel, or in the handbook you'll see a 3 digit code, 1ZL or 1LG. If it says 1ZL then they are 347mm, if 1LG then 321mm. Hope that helps. 1
jazz Posted August 5, 2018 Posted August 5, 2018 Just brought front set of brembo discs turns out there is a size diffrence the new one's are smaller than the one's fitted how do you know the correct size
niedzial1983 Posted August 5, 2018 Posted August 5, 2018 On 5/28/2017 at 8:38 AM, Hoggy1972 said: I just did my fronts this week. If you look on the chassis label either in the boot by the spare wheel, or in the handbook you'll see a 3 digit code, 1ZL or 1LG. If it says 1ZL then they are 347mm, if 1LG then 321mm. Hope that helps. Exactly that ! 🙂 there was aslo 360mm for s6 and rs6
