doublex Posted June 3, 2017 Posted June 3, 2017 Hello My engine vibrates really bad only when it gets warm from 50C to 90C shakes can be felt inside the car, rmp hoping up and down, mpg decreases significantly, fuel smell and white smoke from exhaust (only when it's shaking). When it's cold or warmed up to 90C it's alright. Rmp steady, starts easy and everything works as it should. No faults on dash and computer didn't read any faults either. Why it's only shakes from 50C to 90C? Can someone help diagnose the problem I'm having?
Dan3222 Posted June 3, 2017 Posted June 3, 2017 Sounds like it over feeling until its gets to normal running temps. Too much diesel creates white smoke. I would get the engine codes read live, as the engine goes from cold to operating temperature. It might through up a code temporally that doesn't get stored by the ECU and therefore can't be found just by getting the codes read as it may not get stored.
