123jaye Posted June 14, 2017 Posted June 14, 2017 I'd like to retrofit a flat bottom steering wheel. Like an s3 wheel etc. 聽Can it be done ? Same with the gear knob . Is it possible to fit an聽聽auto s3 gear knob ?聽
Steve Q Posted June 14, 2017 Posted June 14, 2017 18 minutes ago, 123jaye said: I'd like to retrofit a flat bottom steering wheel. Like an s3 wheel etc. 聽Can it be done ? Same with the gear knob . Is it possible to fit an聽聽auto s3 gear knob ?聽 Hi James, yes the steering wheel should be possible. You see it done a lot in the Audi and other vag tuning mags :)聽 I'm unsure about the gear knob though.聽 Cheers steve
123jaye Posted June 15, 2017 Author Posted June 15, 2017 Thanks for your reply . 聽Will look into it a little bit more first . Any ideas which ones would be compatible?聽
Steve Q Posted June 15, 2017 Posted June 15, 2017 I would say easily anything a4 or a6 (obviously) related. Possible a3 but not sure. One thing to bare in mind is that it might not be a case of the steering wheel not fitting but聽more a case of the airbag connections being different and not compatible if that makes sense.聽 Cheers steve
123jaye Posted June 15, 2017 Author Posted June 15, 2017 That's a good point. 聽Plus coding it in as well . 聽Looked about on Google there doesn't seem to be any definite answers.聽
Steve Q Posted June 15, 2017 Posted June 15, 2017 3 minutes ago, 123jaye said: That's a good point. 聽Plus coding it in as well . 聽Looked about on Google there doesn't seem to be any definite answers.聽 As I say, I know it can be done as you see it聽in聽the Audi Tuner mags all the time :)聽 could you聽not look at other steering wheels which were designed for your model i.e. S6 or rs6? Or the accessory wheels on聽offer at the time?聽 This woukd probs be the easiest option to be honest :) cheers steve
123jaye Posted June 15, 2017 Author Posted June 15, 2017 Thanks for your replies 馃槉 probably will look at and rs6 wheel instead
Steve Q Posted June 15, 2017 Posted June 15, 2017 1 hour ago, 123jaye said: Thanks for your replies 馃槉 probably will look at and rs6 wheel instead Your most welcome:)聽
Dan3222 Posted June 15, 2017 Posted June 15, 2017 Consider looking at golf and A3 steering wheels. These are a very commonly used steering wheel of upgrading to what you want. RS6 ones are going to be few and far between and therefore pricey. All are I believe compatable聽to the steering聽column from a VAG car. They even fit Transporters!! You are very much likely going to have to get one coded in to your ECU to allow the buttons to work. Unless you get one from the same year run, 2006-2007 from another A6? Try doing a 247parts (or other online search tools)聽online specific search for the A6 model and then A4 -A3 and so on. See what gets offered back to you and then choose best price.聽 1
Steve Q Posted June 15, 2017 Posted June 15, 2017 5 minutes ago, Dan3222 said: Consider looking at golf and A3 steering wheels. These are a very commonly used steering wheel of upgrading to what you want. RS6 ones are going to be few and far between and therefore pricey. All are I believe compatable聽to the steering聽column from a VAG car. They even fit Transporters!! You are very much likely going to have to get one coded in to your ECU to allow the buttons to work. Unless you get one from the same year run, 2006-2007 from another A6? Try doing a 247parts (or other online search tools)聽online specific search for the A6 model and then A4 -A3 and so on. See what gets offered back to you and then choose best price.聽 I stand corrected :)聽 nice one Dan, it's good to know a3 steering wheels fit and I thought you'd have to have them coded :)聽 cheers steve
Dan3222 Posted June 15, 2017 Posted June 15, 2017 2 hours ago, Steve Q said: I stand corrected :)聽 nice one Dan, it's good to know a3 steering wheels fit and I thought you'd have to have them coded :)聽 cheers steve In fairness I am only quoting what loads of people have done on the T5 forum, the standard ones fitted to the vans are dull to say the least.聽Golf ones are most commonly used but some have used Audi donors. I myself haven't done it though. 聽
Dan3222 Posted June 15, 2017 Posted June 15, 2017 I have just had聽to double check, was starting to doubt myself lol. Here is a pic of a TT one fitted to a T5. There are Seat ones聽fitted too. Of course聽the badge on a VW one won't match though. They all seem to change hands for 3-400 squid though, ouch!!聽 聽
123jaye Posted June 15, 2017 Author Posted June 15, 2017 That's the wheel I already have. For some reason I fancy a newer flat bottom wheel . Just worried about compatibility. 聽Especially if it's costing 300 odd quid聽
Dan3222 Posted June 15, 2017 Posted June 15, 2017 I guess it's whether you think it's worth the money. It does seem like just about any VAG wheel will fit but really best bet is to try to get one from same year if you can. Then There is a chance that all the electric聽will work. Don't forget you could sell your old steering wheel very quickly. I might even be interested for my T5... potentially.
Steve Q Posted June 16, 2017 Posted June 16, 2017 7 hours ago, Dan3222 said: In fairness I am only quoting what loads of people have done on the T5 forum, the standard ones fitted to the vans are dull to say the least.聽Golf ones are most commonly used but some have used Audi donors. I myself haven't done it though. 聽 聽 7 hours ago, Dan3222 said: I have just had聽to double check, was starting to doubt myself lol. 聽 Deffo looks a popular upgrade but I can see why the steering wheels on the vans are naff in comparison to the cars!聽 Sorry for getting you to doubt yourself! Your full of useful info Dan! :)聽 1
