james.grayston Posted June 19, 2017 Share Posted June 19, 2017 Hi all i have a 2013 A4. The air con was working perfect but yesterday started blowing warm air. Any common faults? thanks in advance. Quote Link to comment Share on other sites More sharing options...
Steve Q Posted June 19, 2017 Share Posted June 19, 2017 Welcome to the forum James :) youll find the members on here are a friendly bunch and will help you where they can :) i would suspect at 4 years old your car is due an air con regas or service. This should be done ever 2-3 years as the air con looses gas over time. A regas should cost around £35 and a full service should be around £60. On a full service they'll check for leaks and change the filter. cheers steve Quote Link to comment Share on other sites More sharing options...
Dan0459 Posted June 24, 2017 Share Posted June 24, 2017 Hi James ive just had my Audi serviced and my air con stopped working last week so I asked the garage to do a regas, it was low so the mechanic topped it up and it help pressure but was still not blowing out ice cold. The garage is doing a free diagnostics on it next week but he said it's a common fault the the conpressor goes which I've been warned is not cheap. Will let you know what they find Quote Link to comment Share on other sites More sharing options...
Steve Q Posted June 24, 2017 Share Posted June 24, 2017 Welcome to the forum James :) sorry to hear your having issues, but you'll find members on here are a friendly and helpful bunch :) your right compressors sent cheap! For my old a6 the repair would be around £1000! The only other thing that could be wrong is that the heater panel is stuck on warm despite you turning the knob to cold if that makes sense. Cheers steve Quote Link to comment Share on other sites More sharing options...
