Golfer 17 Posted June 20, 2017 Share Posted June 20, 2017 My A4 has recently developed a very unpleasant smell like damp carpets, particularly evident when opening the door after the car has been left got some time. It does nor appear to come from the aircon. Took it to main dealer who said it is not damp related in that all carpets are dry. They don't know cause and didn't seem particularly desperate to find it. Only recommendation was to hang a fragrance dispenser in the car. Has anyone any helpful suggestions? Quote Link to comment Share on other sites More sharing options...
Brad-B5 Posted June 20, 2017 Share Posted June 20, 2017 Hi Mike Oust should do it but I would get a Air con clean just to be sure. or have a full deep carpet clean (and ceiling) Bradley Quote Link to comment Share on other sites More sharing options...
Steve Q Posted June 20, 2017 Share Posted June 20, 2017 When was your air con last serviced? And pollen filter changed? There could be stuff trapped within the system. Might be worth having the system checked. Where does the smell originate from (front or rear)? If it's front could there be a leak into the cabin under the dash? (Through the bulkhead) Cheers steve Quote Link to comment Share on other sites More sharing options...
Rob F Posted June 20, 2017 Share Posted June 20, 2017 I agree. Check all the above. You can get air con bombs you put in your car and run your air con so it sucks it all in as bacteria and mould can form in your heater sections. Try that. ROB Quote Link to comment Share on other sites More sharing options...
