Juliebest Posted June 24, 2017 Posted June 24, 2017 HELP started having some issues and need help been reading loads of posts now second guessing myself. My issue stated with rear electric window not working so investigation reveals nothing broken, at this point I thought it must be the motor so replaced this and the the window worked. Issue now was no central locking on this door, now again also no electric window what or where do I need to look at I see no obvious issues although not looked at wires from door pillars s I have no idea what wires to check I just know if it goes in the garage it's going be a cost i can't afford at the moment
Audi Owners Club. Posted June 26, 2017 Posted June 26, 2017 Hi Julie....welcome to the Forum I think the easiest method to check where the fault lies is to wiggle the wires within the loom that goes from the pillar into the door while someone holds down the window or locking switch. When the motor works then you know that's where the fault is (either poor connection or broken wire). Let us know how you get on with it Cheers, Trevor
Juliebest Posted June 26, 2017 Author Posted June 26, 2017 Got no joy there my could it be inside the door somewhere it just seems weird that it's started to go wrong would an auto electrician be I good option or an expensive option
niedzial1983 Posted June 26, 2017 Posted June 26, 2017 Vcds scan should be your first step. It may show the issues ans where is it 1
Audi Owners Club. Posted June 27, 2017 Posted June 27, 2017 As niedzial1983 has stated, using VCDS would be the best place to start, so you may be best to find an auto-electrician who has the kit and know-how, and should then be able to go straight to the fault. https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR0.TRC0.H0.TRS0&_nkw=vcds&_sacat=0
Juliebest Posted July 5, 2017 Author Posted July 5, 2017 Well it's strange i had door card removed found no wires damaged window at this point not working no obvious damage to any wires door card back on window switch in rear no working front not working central locking still not working starting to get worried that this is going to be an expensive fix any hope anybody
audi-all-the-way Posted July 10, 2017 Posted July 10, 2017 Hi had this issue with mine, check the wiring between the drivers doors and the body, the wires will be broken
