bewva Posted June 28, 2017 Share Posted June 28, 2017 Just got an A6 Ultra SE. Really impressed with the build quality. I have a couple of questions if someone could oblige; 1. Can the sat nav be set to default to the map on start up to save having to select the map button? 2. Is there an option of speed dials on favorite phone numbers? 3. Is it possible to pair 2 phones to the phone system at once? Thanks Paul Quote Link to comment Share on other sites More sharing options...
Trevor Posted June 29, 2017 Share Posted June 29, 2017 Hi Paul Not the expert on Audi MMI (took me long enough to work out the Honda Infotainment system) 1. Sorry, not sure 2. Speed dial should be standard but would read the manual to find out how to programme the numbers in 3. Should be able to but you might find that one phone will default as a priority....not sure how to change that but does it on my Honda Quote Link to comment Share on other sites More sharing options...
bewva Posted June 29, 2017 Author Share Posted June 29, 2017 Thanks for the reply Trevor. Quote Link to comment Share on other sites More sharing options...
Lanky111 Posted June 29, 2017 Share Posted June 29, 2017 Hi Paul, Some of this could depend on the version of MMI in your Audi - Having some bluetooth issues with my A7 2012 and about to attempt an upgrade to the MMI myself (once I have plucked up the courage!!) You should be able to pair more than one phone and select which is default and change them in the MMI under Bluetooth > Bonded Devices. Some good tips had help topics out on the interweb - one good site - http://mr-fix.info/audi/ and some useful youtubers out there too. Cheers Mark 1 Quote Link to comment Share on other sites More sharing options...
bewva Posted June 29, 2017 Author Share Posted June 29, 2017 Thanks Mark I will have a look. Quote Link to comment Share on other sites More sharing options...
