Just got an A6 Ultra SE. Really impressed with the build quality.
I have a couple of questions if someone could oblige;
1. Can the sat nav be set to default to the map on start up to save having to select the map button?
2. Is there an option of speed dials on favorite phone numbers?
3. Is it possible to pair 2 phones to the phone system at once?
Paul
Hi Paul
Not the expert on Audi MMI (took me long enough to work out the Honda Infotainment system)
1.  Sorry, not sure
2. Speed dial should be standard but would read the manual to find out how to programme the numbers in
3. Should be able to but you might find that one phone will default as a priority....not sure how to change that but does it on my Honda
Thanks for the reply Trevor.
Hi Paul,
Some of this could depend on the version of MMI in your Audi -
Having some bluetooth issues with my A7 2012 and about to attempt an upgrade to the MMI myself (once I have plucked up the courage!!)
You should be able to pair more than one phone and select which is default and change them in the MMI under Bluetooth > Bonded Devices.
Some good tips had help topics out on the interweb - one good site - http://mr-fix.info/audi/
and some useful youtubers out there too.
Mark
Thanks Mark I will have a look.
