Ozzy Posted July 2, 2017 Posted July 2, 2017 Battery went flat so we jump started the car. After following the hand book neither windows work and stuck half way down. The windows were a problem but always worked with the key. Any ideas guys?? I'm desperate, as the car hazards keep flashing now and battery is obviously flattening!!!!!!!!
Steve Q Posted July 2, 2017 Posted July 2, 2017 Welcome to the forum oscar :)聽 youll find the members on here are a friendly and helpful bunch :)聽 Mans I'm sure someone will be able to help :)聽 iv also moved this topic to the a3 section to make it easier for members to find.聽 cheers steve
cliffcoggin Posted July 2, 2017 Posted July 2, 2017 The first question to ask is why the battery went flat? If there was an existing or inherent electrical fault, then fixing the windows might not get聽to the root cause of your problems.
Ozzy Posted July 2, 2017 Author Posted July 2, 2017 I accidentally left my afterkamrket radio on, and the battery went flat over 2 days, so had to charge battery, it worked for the first couple hours but very slowly and then it just got slower and slower and now won't work, help me 馃槴聽
cliffcoggin Posted July 2, 2017 Posted July 2, 2017 Are you saying the battery won't hold a charge? If so, you need to renew it. It would also be wise to wire in the radio properly so that power is removed when the key is taken out of the switch. 1
